Re: gasoline powered 7.3 Power Stroke
Posted by scotc on February 06, 2011 at 19:56:52 from (72.101.231.77):
In Reply to: Re: gasoline powered 7.3 Power Stroke posted by 43warhorse on February 05, 2011 at 18:45:08:
The 6.9 and 7.3 diesels are indirect-injection, compression-ignition engines. The 7.3 Powerstroke, as well as the 6.0, 6.4, and new 6.7, the Duramax, and Cummins are direct-injection compression-ignition engines. Gasoline motors are spark-ignition motors. Compression has to be kept low on them to prevent pre-ignition because the fuel is drawn in with the inatake air, before compression. Compression-ignition motors have the fuel injected into the cylinder near TDC (top dead center), eliminating the chance for pre-detonation.
As for combustion temperature, diesel has about 30-35% more BTU per volume than gasoline. So how does the gasoline burn hotter? It doesn't, it burns colder.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
