Posted by Faster346 on February 06, 2011 at 17:27:15 from (72.241.213.69):
In Reply to: H throttle position posted by Billv75 on January 18, 2011 at 08:16:50:
A lot of 12v tractors are this way. I'm guessing it's because 12v spins them over so fast that they turn over to quick to fire at a lower throttle position.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
