SC WATER PUMP QUESTION PART 2
Posted by powerline on February 06, 2011 at 18:14:07 from (65.41.169.35):
HEY GUYS...A few weeks ago, I had a question if I had the right water pump. (Thanks for the comments & direction.) As I found out from the dealer that I have the correct water pump & shaft. NOW...my next question? Why aren't my pulley's lining up? The water pump pulley wasn't pressed on the shaft from the factory all the way. (I have corrected this.) Now, I have found that neither pulley on the fan shaft will line up with my crankshaft pulley. Could it be I have the wrong thermostat housing on this SC???? It looks correct, but if it had 1/2" more angle forward toward the radiator on the fan adjustment everything would line up. That being said, is there a difference in a C and SC thermostat housing? (Also, this is the correct fan for the SC.) Any help would be appreciated...thanks for the info. in advance!!!
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
