As far as I know the Super C did not come without a water pump and according to my parts info, only one water outlet fitting (which supports the fan shaft) is listed. That is part number 257353 R2. For the C, the water pump was optional and most did not have it. With the water pump, the outlet fitting and fan support is the same as the SC. Without the water pump, the outlet fitting part number is 251177 R1. I don't think the C without the water pump had provision in the water outlet for a thermostat. So there are two possibilities for the water outlet fitting, however I'm betting there is no difference in the position of the fan. So I'm guessing you have some other issue on the belt alignment.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
