head gasket change
Posted by Russ from Canada on February 07, 2011 at 08:15:28 from (173.183.175.40):
I am changing a blown head gasket and cannot find the timing mark T . ther is a 0 and a bunch of marks then 10. Turner flywheel c/w until static timing marks on inj. pmp. lined up then removed head. Number 1 piston was app. 3/8 in. below top of stroke. Turned f/w until piston at top, cleaned up and check for warpage all ok. Put head on and put rods back in. # 1 intake and # 4 intake and exhaust rods app 3 inches too high all others ok. Tried to tap them down with block of wood and hammer. no luck there. turned f/w 2 rev. until t/m lined up on inj. pmp. again stii no gosame rods high.what do I need to do. it is -30 up here and want spend as little time outside as possible. Thanks for any and all help Russ
