Posted by pete 23 on February 07, 2011 at 10:37:58 from (173.87.15.134):
In Reply to: head gasket change posted by Russ from Canada on February 07, 2011 at 08:15:28:
The tappets in a 282 can definetly pull out of the bore in the block when you pull push rod out. That is the only thing I can think of that would cause your push rod to be too high or low. If tappet is all the way out the push rod will go down too far so it must be up and cocked. It is pretty hard to do much down the little hole in head where push rod goes through. Probably can see down there to verify problem but have to pull side cover off to get them back in place. The trick is to jiggle those push rods when pulling them out so they let go of the tappet. Good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
