Re: 6 volts to 12 volts
Posted by Faster346 on February 07, 2011 at 17:58:14 from (72.241.213.69):
In Reply to: 6 volts to 12 volts posted by gene bender on February 06, 2011 at 13:22:09:
So what do you do, make it charge 12v, and put a 12v battery in it and leave it negative ground??
