Re: 6 volts to 12 volts
Posted by Dieselcowboy on February 07, 2011 at 18:11:08 from (99.130.204.45):
In Reply to: Re: 6 volts to 12 volts posted by Faster346 on February 07, 2011 at 17:58:14:
A regulator is a generator's boss. So one of those a coil with internal regulator( this way you don't have to have a resister wired on the outside), 12 battery hooked up neg ground, if you change from postive ground don't forget to swap your amp gauge wires side for side. No changes to the main wires needed. It is a 20 minute deal if you have all your parts before hand. Pretty slick huh.
