Make sure the nut on top of the gear is tight. You may also turn the gear 180 degrees so it's on a spot that isn't as worn. The bearing on the worm shaft could also be bad. My 400 was flat dangerous going down the road because it shook so bad. I turned the gear and put in a new bearing and it is like new now. The worm gear bearing number comes up as some weird $150.00 bearing but I replaced mine with a 6207 (pretty sure that's the right number) motor bearing for a couple bucks.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
