D188 in a IH 504 Starter ring gear puzzle
Posted by Pandora 504 on February 08, 2011 at 12:06:22 from (75.197.116.224):
My 504 has chewed up the flywheel ring gear so I need to replace it. After a little digging I found that the # of teeth was changed from 134 to 133 at serial#13676. Also the starter drive was changed at the same time,I am guessing to change gear ratio to improve starting. Does anybody know anything about this? I am wondering if I can use the later(133 teeth) ring gear on my current flywheel with the newer starter. Parts book does not list flywheel without the ring gear so I dont know if it is the same. Thanks for any advice you might offer.
