Posted by M Diesel on February 10, 2011 at 15:20:22 from (12.24.61.12):
In Reply to: Farmall 450D posted by El Toro on February 09, 2011 at 12:21:33:
They have a tendency to do that on the smaller gas starts from what I have seen. My MD is prone to it from time to time. Old injection parts are a bit worn.
The odd shape of the exhaust manifold makes them hard to check but you can feel the injector lines with finger tips. Running cylinders have a stronger pulse due to pressure build up in the cylinder while firing. It will feel more crisp. And do the injector bleeder test.
Also, pull the spark plugs and look for crud. It helps to tell if the starting valves are sealing off. You can pull them while running but it is a bit of a pain.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
