Re: Where is the middle? Super A question
Posted by snoop-nc on February 11, 2011 at 08:13:43 from (66.226.60.8):
In Reply to: Where is the middle? Super A question posted by Farmall-H on February 10, 2011 at 19:10:30:
COLE: You wrote: ".... looking at the row you are cultivating"
I picked up on you are trying to adjust your cultivators from side to side.
Suggest you check on the width between inside sidewalls of tires and get that adjusted to your desired row width/spacing. Consult your operators manual.
THEN you should be able to adjust the spacing of your cultivator to where the center line from tire spacing would be the "centerline" while cultivating.
I don't think there is any "gun type sight" per se.
Others may have a different "read" on your question and will likely chime in.
Good luck on your gardening this year.
Rick
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
