Re: Where is the middle? Super A question
Posted by snoop-nc on February 11, 2011 at 08:36:40 from (66.226.60.8):
In Reply to: Re: Where is the middle? Super A question posted by snoop-nc on February 11, 2011 at 08:13:43:
COLE: I wrote: "THEN you should be able to adjust the spacing of your cultivator to where the center line from tire spacing would be the "centerline" while cultivating."
On second reading...after posting...I don't believe what I wrote is quite right.
Your "centerline while cultivating" should be closer to right side of tractor and the rows be clearly visible as you are moving...passing under the seat area of tractor.
I believe you'll also need to adjust spacing between your rear sweeps to eliminate your tractor tracks.
Sorry for the possible confusion.
