Re: No oil pressure.
Posted by dblair on February 11, 2011 at 15:08:13 from (98.140.24.21):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
I wonder if it could be the same thing that plagues the M some . the guts of the oil pump may be wore out .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
