Re: No oil pressure.
Posted by Wardner on February 11, 2011 at 15:50:54 from (209.86.226.12):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
If the block was hot tanked, it is possible that all the gallery plugs were not re-installed.
I might start by attaching an air hose to any oil plug port and trying to locate a large air leak by ear. You may have to move the tractor out of earshot of your compressor.
If your engine has galleries similar to a Cub, remove the tappet cover and carefully look for a missing plug between the 2nd and 3rd cylinder. There may be another one behind the camshaft gear.
