Re: No oil pressure.
Posted by Charles E. McNelly on February 11, 2011 at 16:11:22 from (72.18.77.250):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
I would say the number 1 reason for these motors to have low low oil pressure is the junk pewter plate at the bottom of the oil pump. I too have had issues with this. I took the plate off the pump, and with the help of wet/dry sandpaper and a piece of glass... I"m up and running again. If anyone makes this plate out of steel, let me know. I"ll buy 2 for sure! Poor design to say the least.
Good luck,
Charles
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
