Re: No oil pressure.
Posted by CharlieNJ on February 11, 2011 at 16:17:11 from (174.57.220.136):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
Blow some cigar smoke through a small hose down the rocker oil hole, see where it comes out. I once found a gallery plug that blew out on a truck that way.
Best Regards,
Charlie
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
