Re: No oil pressure.
Posted by Owen Aaland on February 11, 2011 at 16:28:31 from (63.167.132.13):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
You need to make up your own reinforcement bar for the plate. Start with a piece of steel 1/2" x 1/4", long enough to span the side of the cover where it warps. They all warp on the pressure/output side of the gears. Drill a couple of holes and use 1/4" longer bolts to mount it to the cover. You will need to make a small notch in it near the center to get it to clear a rib on the cover. I also like to put a small bend in the middle to make sure it contacts the cover in the middle of the span before it gets all the way tight on the ends.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
