Posted by CNKS on February 11, 2011 at 17:37:03 from (216.144.104.128):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
The oil pump has a NEW end (bottom) plate. As stated clearance is within spec. Several mentioned missing plugs -- I don't think so but anything is possible, I guess. I don't remember any under the front cover, that is about the only place where if missing that it wouldn't cause a very visible leak? Owen mentioned that the pump would prime within 2 minutes. I have not let it run anywhere near that long. This is only the 2nd engine I have rebuilt. The first was in a 460, it had almost immediate oil pressure. I can't see how the pump could be bad, besides it was working ok before the overhaul.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
