Posted by CNKS on February 11, 2011 at 17:57:27 from (216.144.104.128):
In Reply to: Re: No oil pressure. posted by Owen Aaland on February 11, 2011 at 16:06:42:
Yes, 0.010. The machinest removed the governor bearing before hot tanking -- that's why I was wondering if the hot tanking could possibly damage the boring in the cast for the rest of the cam holes. I asked above about the 2 minute priming. In rereading I think you meant self priming with the engine off. I have run the engine maybe 15 seconds each time. looking up at the engine with the pan off, I see oil about everywhere (can't see inside the bearings), but that could be just splash from the crankshaft. I assume that if it does not show pressure in a few seconds, it never will?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
