Re: No oil pressure.
Posted by Owen Aaland on February 11, 2011 at 18:49:30 from (63.167.132.13):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
The picture in the parts listing does not show the plugs for the oil galley but they are listed under the block assembly. You can see the hole for the rear one in the drawing. There are two expansion plugs, one for the cooling system and the other for the camshaft. there is another hole slightly below that where the galley plug goes. the oil galley goes all the way through the engine and comes out behind the gears. The oil pressure gauge fitting is also connected to the same oil galley as well as the top outlet of the oil pump.
I don't have another block to look at but the front plug would be the most likely to be left out. Like you said, the rear owe would have a heck of a leak by the flywheel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
