Re: No oil pressure.
Posted by CNKS on February 12, 2011 at 08:29:44 from (216.144.104.128):
In Reply to: Re: No oil pressure. posted by El Toro on February 12, 2011 at 08:20:19:
Unfortunately, that box is long gone. But, I don't think I would have tossed it until I got all the plugs in. I have several plugs of various sizes, off of more than one tractor, but they are all painted red, internal should be unpainted, and none of them are the small "set screw" type like the rest are to access the passage. If it is not the pump, then the only possibilities is one behind the front cover, or internal somewhere else. I would appreciate the call though -- thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
