Re: No oil pressure.
Posted by El Toro on February 12, 2011 at 08:20:19 from (108.3.200.96):
In Reply to: Re: No oil pressure. posted by CNKS on February 12, 2011 at 08:03:58:
I would look in that box to see what's left over and if there's any pipe plugs. When I did the Farmall A back in 1975 I didn't have the block hot tanked. I took the block to work and used a steam jenny to clean it. There's a man in SC that's doing a Super A. His name is Sam Eubanks and I'll give him a call to see if he knows about the pipe plugs. He use to post on here, but I haven't seen him lately. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
