Re: My Super C doesn't have a water pump??
Posted by ScottyHOMeY on February 12, 2011 at 18:11:00 from (70.105.243.38):
In Reply to: My Super C doesn't have a water pump?? posted by Faster346 on February 12, 2011 at 17:00:14:
Look for the third pulley on your fan drive belt. There should be the crank pulley and the fan. The third one, over on the left side of the tractor, is your water pump. It takes the place of the simple double-elbow inlet of the thermosiphon, between the radiator and block on the lower side.
