Re: I need some help with a F-14
Posted by F14 on July 15, 2000 at 11:00:15 from (216.252.28.150):
In Reply to: I need some help with a F-14 posted by TJK on July 15, 2000 at 08:35:01:
Yup, what Mike said, with a couple of additions:
The black smoke is a tip. Black smoke is unburnt fuel, so it sounds like she's getting more then she can swallow when you throttle up. This could be mixture adjustments, float setting or governor adjustment. Also, check the plugs and see if they're fouling.
Less likely, but possible: If the mag is way retarded, or you're not advancing it with the lever after starting, it will bog when throttling up.
Post A Followup
: Re: Re: I need some help with a F-14
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
