Re: No oil pressure.
Posted by Dennis K (WA) on February 13, 2011 at 09:28:26 from (24.21.78.195):
In Reply to: No oil pressure. posted by CNKS on February 11, 2011 at 15:01:40:
There is definitely a plug hole behind the cam gear next to the cam retainer plate at the end of the oil galley. 1/4'' pipe I believe. Could be easily missed.
Good luck
Dennis
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
