Posted by Moki on February 16, 2011 at 17:07:09 from (64.109.36.50):
I had my H overhauled a while back and ever since it has a surge at the lower throttle settings. I helped in this overhaul and can't tell if I have the throttle shaft connected to the governor correctly or not. It appears to me that there should be a spring on either side of the pivot point. Do these springs need to be replaced? Is it likely that the carburetor might need adjusting and cleaning? This tractor has done hardly any work in its life and never had the surge before the overhaul. Maybe someone out there has had a similar experience? I had it overhauled because it seemed like a little oil was getting past the rings, etc. It sat a lot during its lifetime on my uncle's farm.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
