Re: H Surging
Posted by Farmall_H_Puller on February 16, 2011 at 17:25:03 from (174.60.115.104):
In Reply to: H Surging posted by Moki on February 16, 2011 at 17:07:09:
You need to adjust the throttle shaft going from the govenor to the carburetor it is not aligned right. My H did the same thing after I took it off to fix a leak and I moved it up a little bit and it stopped the surging.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
