Posted by Dellbertt on February 17, 2011 at 04:06:34 from (209.172.21.104):
300U Manual Steering with stock short arms.
I have developed a lot of slop in the right side pitman arm (gear shaft). The right side steering wobbles when traveling and the left side does not.
Gearbox does not leak.
There is no up and down play in steering shaft and no slop or play in the left pitman arm (lever shaft)
With front wheels off the ground and holding the steering wheel stationery I can not move the left pitman (no slop) but I can move the bottom end of the right pitman more that an inch (lots of slop).
I believe the eccentric adjustment (#21 a & b IT) adjusts the right side gearbox case to mesh the lever shaft and gear shaft closer but I have to change dowels in order to make that correction last.
The other two adjusting screws (#9 IT) are to adjust any side to side slop in the lever and gear shafts. There is about a ¼ inch sideway play in the gear shaft. Is that enough to let it jump teeth.
If I have a misunderstanding of the adjustment screws please advice.
It’s just to cold in my old barn to tackle a rebuild project now, so I’m open to any suggestions that will make it last till the weather warms.
Thanks,
Dell
This post was edited by Dellbertt at 05:18:26 02/17/11.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
