The front sheet metal is removed, then the large nut on the front of the steering gear box is removed (lefty loosy) then the steering shaft screws out of the box (turning it causes it to moove past the sector gear and it is removed out the front. The only worst case is if someone welded the universal yoke to the shaft. Then it may be necessary to grind off the weld to get the shaft through the radiator. Jim
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
