Posted by Travis Atkinson on February 17, 2011 at 17:23:00 from (4.225.175.92):
I have an 856 international with hydraulic problems. The old tractor runs great and 3 point lift works fine.When I start tractor power steering,TA and brakes don't work. I can let it run for awhile and they start workig most of the time. I don't know if I am right but acts to me like a valve may be sticking.Wondering if there is something I can try before taking valve body apart for inpection. I have heard adding some diesel fuel to oil will clean valves but have not tried it yet. Just open for any suggestions at this point.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
