This is a common problem for tractors where it has been many years since they were split between the center section and the rear frame. there is an O-ring seal between those two housings to connect the suction side of the MCV pump. As the o-rings ages it becomes less effective at sealing between the two housings. Since the seal is above the oil level air enters on the suction side of the pump. When you start the tractor this air is drawn into the MCV pump which is not very good at pumping air.
The short term solution is to add about five to seven gallons of oil above the full mark on the stick. That puts the oil level above the seal so air will no longer enter the MCV pump. The only downside is that when you change hydraulic filters you will also drain out some of this extra oil.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
