I may be wrong on this, but I believe the correct marks should be in position next to the governor gear to do the alignment when the engine is turned to #1 TDC. Set your engine at #1 TDC . Whether the marks are one each on adjacent teeth or close together between two teeth, just use them.
In any case, after installing the governor, the distributor drive slot should be about 35 degrees off of horizontal. (oriented 2 - 8 o'clock when viewed from the distributor end). If you have that orientation at TDC, you are in business.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
