Super A timing followup
Posted by CNKS on February 16, 2011 at 17:56:09 from (216.144.104.128):
In classic view, the post dropped to page 2, it is in the link. Briefly, the timing marks do not line up at TDC. My long explanation in the link is incorrect, as I tried starting the tractor with the timing marks aligned, and again with the piston at TDC. In both cases the engine begins turning and stops, meaning the spark is occuring at the wrong time. This tractor ran before, did not have oil pressure which I corrected by removing the governor and plugging the hole at the end of the oil galley. Obviously I reinstalled the governor wrong. But, I did not find a double punch mark on the cam gear as the service manual said, but single marks on two adjacent teeth, I put the double mark on the governor gear between the two singles on the cam gear, thinking that was the "double" referred to. Wrong. So I'll see what I find tomorrow and report back if I ever get it fixed.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
