Re: 560 update from last night--dry sleeve insert explosi...
Posted by Janicholson on February 18, 2011 at 11:04:06 from (199.17.6.194):
In Reply to: 560 update from last night--dry sleeve insert explosion-Why? posted by NolanJae on February 18, 2011 at 10:53:28:
The most likely is a loose sleeve in the cast block bore. The thermal loads when it is not as tight, and the ringing (as a bell) can stress crack the sleeve at the point where the retaining ring meets the main part of the sleeve. The sleeve creeps lower in the cylinder until the top ring expands out over it and drags the sleeve into rotating parts. Jim
