Re: 560 update from last night--dry sleeve insert explosion-
Posted by rustyfarmall on February 18, 2011 at 11:41:21 from (209.152.78.140):
In Reply to: 560 update from last night--dry sleeve insert explosion-Why? posted by oldtanker on February 18, 2011 at 10:53:28:
Is the 560 engine one of those that didn't use the exact same sized sleeve in each cylinder? Is there some sort of number or code stamped into the top of the block right next to the cylinder with the damaged sleeve? It is highly possible the previous owner did not know, and installed a "standard" sleeve set where one of the cylinders SHOULD have had a slightly larger O.D. sleeve.
