Re: 560 update from last night--dry sleeve insert explosi...
Posted by Farmboy856 on February 18, 2011 at 15:15:00 from (74.215.181.71):
In Reply to: 560 update from last night--dry sleeve insert explosion-Why? posted by NolanJae on February 18, 2011 at 10:53:28:
I was a little kid at the time, but our first 560D developed an odd tapping sound while still under warranty. The local dealer tore it down and replaced the sleeves and pistons with the correctly lettered ones. It seems that some of the early ones got out of the factory with the wrong ones in them. I remember that they put a bead of white lead around the new sleeves before they drove them in, which was the recommendation from the company. Ours ran for years after that with no problem. This was a tractor that had the rear casting marked meaning it had had the heavier gears installed before delivery, so it had to have been an earlier tractor.
