Re: H carb gas leak
Posted by Owen Aaland on February 18, 2011 at 16:52:43 from (65.174.247.39):
In Reply to: H carb gas leak posted by Zachary Hoyt on February 18, 2011 at 15:45:08:
The brass nut with the screw driver slot hold the metering nozzle in place in the fuel bowl. It appears that the gasket is leaking between that nut and the fuel bowl and the fuel running down and back from there.
You are also missing the felt filter and retainer from the drip hole. Without it dirt can enter the carburetor without going through the air filter.
