Early engines had a looser fitting sleeve than the later engines. Some sleeves could be installed all the way in with just hand pressure. The sleeves are held in place by the head gasket instead of friction in the block bore. Most of the time you are better off getting the .002" oversize sleeves and then honing the block a little if they are too tight. If the sleeve flange height varied too much between adjacent cylinders it could allow a low low sleeve to move in the block. There are shims available to adjust sleeve flange height for these early blocks.
If ether was improperly used to start the engine it could also lead to cracking of the sleeve flange. Ether should not be sprayed into the intake unless the engine is already cranking over and never used if the glow plugs are being used. This type of breakage is not unusual with engines that have seen a lot of ether to start them. You will also find it in the later engines with the press fit sleeve and in the D361 and D407 engines. Sometimes when a head is removed you will find evidence where a piece of sleeve flange has broken off and left it's mark on the piston and head.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
