Posted by DanB (OH) on February 18, 2011 at 18:37:43 from (66.166.229.62):
I have a 52 Super M that is new to me. Was in the family and run hard in the 60's & 70's. It is a wide front end and I found a loader for it on Ebay. Put the loader on, found the Hyd/Tran fluid to be low, now is where the problems and questions start. It has a lift all bell pump. 1. filled up the fluid, now it leaks plate size spot over night. Where do I start to fix the leak? drips on casting splits and bolts. 2. It does not life up very far or very fast. Is the 6qts in the system enough for the big lift cylinders? This tip loader came of a standard M so it should have worked sometime. 3. I still have the little catch on the operating rod. It does not hold up when the rod catch is at the bracket. It should go up when pulled all the way toward me, hold at the middle and then go down if you lift it up and push the rod all the way forward, correct. 4. What are the best ways and aprox cost for going to live Hyd? Really appriciate and tips or thoughts!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
