300U Knuckle/Front Arm adjust
Posted by Dellbertt on February 19, 2011 at 04:26:03 from (209.172.21.188):
300U Manual Steering
I followed the service manual instructions to the letter adjusting the steering setup.
I have the adjustable front axle so if you match the marks on the gearbox/ pitman and the knuckle/arm it should give you the recommended ¼ to 3/8 toe in.
I have all the marks matched but I have about a 4in toe in.
Question: Is there a mark or keyway on the front knuckle shaft splines so the arm is installed in the factory or stock position?
As long as I have the drag links, pitman and front arm correct I could remove the front arms and move a few splines for the correct toe in but I really hate messing with the front arms and knuckle splines because they have not given me an ounce of trouble in 20years. (I bought the tractor from the original owner)
Thanks,
Dell
