Re: Non running cub
Posted by GriffNC on February 19, 2011 at 19:15:37 from (71.53.107.175):
In Reply to: Non running cub posted by Kyrock on February 19, 2011 at 19:11:47:
Did you rebuild the carb ? Soak it over night in carb cleaner and clean out interior passages ?? Float set correctly ? That is an easy carb to rebuild with a good kit !
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
