Non running cub
Posted by Kyrock on February 19, 2011 at 19:11:47 from (74.136.5.233):
I recently purchased a non running cub,after pulling the carb and gas tank, I thought I knew why it would not run, The carb and settle bulb were full of varnish, cleand tank,bulb, and carb, put back together. Now it will start and run somewhat. If you spray starting fluid in the breather tube it runs fine,Gas is getting to the carb..Whats my next move......Thanks
