Re: SM Clutch
Posted by Janicholson on February 20, 2011 at 07:51:04 from (67.72.98.45):
In Reply to: SM Clutch posted by Bud Kaiser on February 19, 2011 at 13:04:13:
I still do not believe the clutch is at fault.
Take the linkage rod off of the outside of the tractor. Leave the front short lever in place. Put a large adjustable wrench on it as a handle and look at the clutch and TO bearing as it is moved. If the clutch now releases correctly, the issue is in your reassembly of the pedal system. What was the reason you removed the pedal pivot?
Was anything replaced in that area? Was the rod replaced?
If the clutch will not depress (inside when moved by a wrench) the two keys might be sheared on the shaft inside the housing, these keys operate the throwout bearing fork to shaft. Jim
Where
