SM Clutch
Posted by Bud Kaiser on February 19, 2011 at 13:04:13 from (75.0.253.159):
I replaced the brake and clutch shaft then started up tractor no clutch.I lowed the belly pump and checked operation all looks normal ecept all 3 fingers are almost flat on the pressure plate. I took the bolts a few turns loose on the pressure plate then the fingers will be at an angel and clutch has feel but when I tighened it up same thing fingers almost flat.
I see no broken springs and I am stumped why this happened.I just thought someone might be able to save me from spliting the tractor.
Thanks
