Posted by Janicholson on February 20, 2011 at 18:05:18 from (67.72.98.45):
In Reply to: Non running cub posted by Kyrock on February 19, 2011 at 19:11:47:
There is a possibility that the carb needs more cleaning. (or) Was fuel able to be drained out of the carb at a rate approaching 3/16" stream? if not it is still plugged up somewhere in the delivery system. There is a screen at the carb inlet that is often overlooked. Is the intake manifold leaking air at the engine flange or the carb flange, either will be a vacuum leak and cause lean running. Good luck, and keep us in the loop. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
