Re: engine rebuild - need to have some advice
Posted by ltf in nc on July 17, 2000 at 10:42:14 from (206.228.214.79):
In Reply to: engine rebuild - need to have some advice posted by tom on July 17, 2000 at 09:52:49:
You need to verify if this engine has valve guide seals. If the engine does that may be all that you need to do. Oil is running down the exhaust valve stems and is being blown out the exhaust unburned.
Post A Followup
: Re: Re: engine rebuild - need to have some advice
