Re: Re: engine rebuild - need to have some advice
Posted by Dick B on July 17, 2000 at 23:19:04 from (152.163.204.40):
In Reply to: Re: engine rebuild - need to have some advice posted by ltf in nc on July 17, 2000 at 10:42:14:
Shouldn't that read oil is being drawn in the combustion chamber through worn intake guides because of engine vacuum. I've always understood
oil is not drawn into the combustion chamber through worn exhaust guides because the during the exhaust stroke the chamber is pressurized.
Some oil may leak through the guides when the engine is shut down, but this is burned during the first few revolutions after start up, emitted
blue smoke for a short time. Plumb a vacuum gauge
into the intake manifold and do some vacuum analysis work. The problem will be quickly found if the vacuum gauge instructions are closely followed.
Post A Followup
: Re: Re: Re: engine rebuild - need to have some advice
