Re: 1938/F 20 wierd cooling problem
Posted by 36F30 on February 23, 2011 at 15:28:26 from (71.214.217.123):
In Reply to: 1938/F 20 wierd cooling problem posted by Dan Oehmke on February 23, 2011 at 15:13:01:
Good news, your thermosiphion cooling system is working perfectly. Hot water from the block enters on the top, gets cooled by the fan and exits the bottom. no pumps or t stats just physics. To drain the block you can take the lower elbow off the side of the block, but it will all drain out the bottom of the radiator.
The pipe plug hole is where the crankcase ventilation tube should be.
Heres one on a F30
third party image
This post was edited by 36F30 at 15:30:35 02/23/11.
