1938/F 20 wierd cooling problem
Posted by tugboattim on February 23, 2011 at 15:13:01 from (166.139.5.219):
hey all I just got a f-20 with no wter pump stock orig tractor. After running under load for a time the top tank is hot the bottom is coold ice cold ..I dropped a brazing rod through the top and all the rad tubes seem clean. is there a thermostat hidden somewhere?? i'm sure I'm going to prbley be replacing the head gasket it's leaking in the front corner. Also there is a 3/8th pipethread hole in the rear of block on the corner down by bell housing same side as mag.. thought it would be a block drain but no water comes out.. may need manual thanks in advance for any advice
